Toyota Hilux 2008 Turning
13 years 2 months before #33195 by manual-mecanica
Toyota Hilux 2008 Tour of the steering wheel published by Manual-Mecanica
Good afternoon,
someone can help me to tell me if it is communicated that the flyer of a car turns less amounts of turns from center to left than from center to right, if not. How can I correct this problem, my terminals are all new?
Greetings.
13 years 2 months before #33221 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota Hilux 2008 Tour of the steering wheel
No, it is not normal that is a problem with the address box or with the arrow.
13 years 2 months before - 13 years 2 months before #33224 by manual-mecanica
And as I do to correct this, that I need to release and tighten. what would be the procedure to follow.
As I do to correct the direction of my car, one of the terminals does not give more in Roz to continue aligning it and if the helon is adjusted it is that it turns more around than the other.
Latest edition: 13 years 2 months before by .
13 years 2 months before #33231 by manual-mecanica
Vergara is not normal ... if this happens, I would have less angle of turn to the left and this should be equally on both sides. You would have to see the top of each side or if on the left side does not reach its stop, there is something that stops it in the zipper or the symphin ... Slds.
13 years 2 months before #33256 by manual-mecanica
Czech first where the prismatic Brazo is and checks that the striatum is not turned, if it is not to make it more or less focused the steering wheel telling the total turns and dividing it by two then you put the direction in the half -owned number and take out the prismatic Brazo and put it straight and tests, it is half tedious but it works.
