Toyota Hilux 2008 Luz T-Belt (turns off)
13 years 2 months before #33196 by manual-mecanica
Toyota Hilux 2008 Luz T-Belt (turns off) published by Manual-Mecanica
Good afternoon.
Dear senhores, someone knows how to review and turn off the light of the time strap or (T-Betl) that comes out on the board when changing that belt in a 2008 Hulix.
Cordial greetings.
13 years 2 months before #33261 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota Hilux 2008 Luz T-Belt (turn off)
Hello
to turn off the Light of the T-Belt unvez changing the belt and after having made the change.
You enter the vehicle you open the Switch you look at Millero Q says (ODO) and and present all the miles traveled.
If time then you close the Switch you precise the mile brand button with the precin Luzzzz ..
13 years 2 months before #33297 by manual-mecanica
Thanks friend, your help has been very useful.
The procedures that you have given me worked 100%.
I am entirely.
Kind regards.
13 years 2 months before #33302 by manual-mecanica
Fransisco0909, I would like to post entity in the section of known mechanical problems, it would be admitted to the page for the subsequent help of other foristas, if it is not a clear problem, once you have you notify me to allow your publication there, there is very interesting data of common failures in the vehicles only the fault and its solution by brand and year brand, it is still Very use, if you do me the favor I will be very grateful, abrasy and luck.
13 years 2 months before #33316 by manual-mecanica
Greetings Kikemec
is already posted the subject in the section and mechanical problems.
