Seat 1.9D immobilizer
13 years 2 months before #33611 by manual-mecanica
Seat 1.9D immobilizer published by Manual-Mecanica
Hello everyone!
I have a problem with my Seat Inca 1.9D Motor 1y, and is it spoiled the immobile of the unemployment valve. Someone could tell me how could the immobilizer cancel?
Thank you very much and greetings.
13 years 2 months before #33638 by manual-mecanica
Manual-Mecanica Response on the Re: Seat 1.9D immobilizer
Some models of immobilisators the oldest are solenoid, the only thing you have to do is to send it positive from the contact key when the engine is in ignition and you will avilitate the fuel and when the veículus turns off, this electrovalvula closes and stops the motor's gear ... already when you have electro injectors you can not because the immobilisator works in the EDC blocking the EDC blocking the injection pulse (in the case of the Rail Cammon)
13 years 2 months before #33639 by manual-mecanica
CLARASION: When I referred to the oldest it was to the mechanical injection diesel .. (with or without electronic assistance)
9 years 6 days before #51222 by manual-mecanica
Manual-Mecanica Response on the Seat 1.9D immobilizer
GOOD with patience drilling the Tornyl removes the entire plastic cover even if you break and put the valve a positive one that cuts the key.
