VW Golf TDI out of point
17 years 4 weeks before #3407 by manual-mecanica
VW Golf TDI Out of point published by Manual-Mecanica
Hello everyone I tell you that in the workshop we have replaced the cylinder cover, and when trying to start the car, it has been out of fucking since the marks in the new pulleys are displaced. If anyone knows about any set -up manual, he is appreciated in advance.
17 years 3 weeks before #3434 by manual-mecanica
Manual-Mecanica Answer on the Re: VW Golf TDI
You need the utensils to put it into point as it should or if not the piston one above and the valves in compression you will see the cylinder one and four
17 years 3 weeks before #3444 by manual-mecanica
hello good. In the gearbox in the upper part there is a register K if you see it you will see that there is a kind of skewer in the form of a tip you have to agree with a mark on the engine steering wheel the camshaft has to stay the crossing in the cylinder 1 you will see at the final end of the tree that has a brand and keda parallel to the butt should enter a foot of Rei. And the bomb puts a 12 pin on the pulley. Now you have all the brands well you have it ready.
