Problem with the VW Pole 1.9 SD gearbox
17 years 1 month before #3412 by manual-mecanica
Problem with the VW Polo gearbox 1.9 SD published by Manual-Mecanica
I have problems in the 1.9 pole gearbox and I need the curling of the box because I can't disarm it thanks.
17 years 1 month before #3413 by manual-mecanica
Manual-Mecanica Answer on the Suzuki Jimny
Please I need you to help me about the colors of the main window switch cables, I don't know where they are connected thanks.
17 years 1 month before #3417 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with the VW Pole 1.9 SD gearbox
You do not even be interested in that manual but I have the original self -taught manual of the 2005 1.8 Pole box. I am not sure that it is the same box but it must look like a lot, if you need to confirm me.
17 years 1 month before #3426 by manual-mecanica
Yes, if you can send me I thank you.
My email is polobor@yahoo.com.ar
A hug Manuel.
15 years 2 months before #13775 by manual-mecanica
Siaun you need the manual tell me what type of motor (in letters bah, apk, akl, alm) that come detailed in the enrollment is the car and in the box there are also some letters (DPL) that indicate the type of box that is to see how I can help you.
