Peugeot 307 cc hood
13 years 1 month before #34419 by manual-mecanica
Peugeot 307 cc capota published by Manual-Mecanica
Hello everyone:
it turns out that I recently went on a trip and my arrival at the place I discamon my leoncito (I call it hehehe) everything perfect, until the moment of hooding it again since the roof rises, the two arms that come out also but the capota stays through Trallecto, and my question is if you know how to fix it and not spend the 350 euros they ask me for doing so.
A ABS and ESP failures also come out, but according to me there are if I have to take it to the house to connect it to the PC, not?
Well if you could help me, I would appreciate it.
13 years 1 month before #34443 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 307 cc hood
What a workshop can make the fault scanner, with respect to the roof what is usually done and before taking it to the commercial house is to act the system by hand, by means of a tool that is in the trunk and puts in an Allen pernito that is there it is and goes down and then rises again and tests with the buttons to see what happens.
13 years 1 month before #34451 by manual-mecanica
Hello Kikemec, I have already tried the hand system since when the fault occurred I was not in my town and it has not worked. The question was if you knew how to fix it without taking it to the workshop.
13 years 1 month before #34477 by manual-mecanica
That is a ceiling position sensor, and without PC to know which one, since it has several
13 years 1 month before #34507 by manual-mecanica
You are right, it is difficult to determine since you would have to check them all.
