Mercedez Sprinter 313 CDI problem
13 years 1 month before #34735 by manual-mecanica
Mercedez Sprinter 313 CDI problem published by Manual-Mecanica
Ola I have a doubt with the Mercedez Sprinter 313Cdi the vehicle is normally spends about 10 minutes and the vehicle stops I have to wait a bit to be able to start it again .... Making purchase supplies the fuse box changes all filters. But where is the odometer, the light witnessing light appears to me and a letter that is to check the oil level and is past the maximum that can be the cause of the vehicle stopping ???????
13 years 1 month before #34795 by manual-mecanica
Manual-Mecanica Answer on the Re: Mercedez Sprinter 313 CDI problem
Check the particle filter they usually obstruct
8 years 6 months before #51781 by manual-mecanica
Manual-Mecanica Response on the problem Mercedez Sprinter 313 CDI
I think that the problem can be in the fuel tank and in the fuel lines to the filters, there must be dirt that covers them partially, and the level is because the transfer pump lets the diesel pass to the carter you have to disassemble the pump and check the stamps. These types of failures are never reflected in the scanner.
