Hello.
I have a question, to see if someone can clarify, please.
I have changed to my father's Opel combo the full engine set plus gearbox of another damaged combo.
After finishing the work, when it comes to scratching, the engine did not scratch and I have realized that the new engine injection pump that I have put carries an immobilizer with a electrovalve with a plug with 3 cables, to the comparison with the old engine that its pump did not carry immobilizer and its electrovalve carried a connector only with a cable.
The immobilizer carries a plastic box and the electrovalvula is not seen as the other pump that does not carry immobilizer and the electrovalve is seen and can be disassembled.
The question is, can you remove the electrovalve without immobilizer from the old pump and put the new one instead of the immobilizer?
Or do you need to leave the pump with immobilizer and also change the wiring with the other car's immobilizer switchboard?
Thank you
