People: My ranger stayed without oil pressure. I got the carter and the sucker was clean. The pump, I was hunting or behind the distribution, but disarms, without taking out the gears and I still do not see it. Are you behind the gear assembly? on the crankshaft axis? If someone guides me, I appreciate it.
The oil pump has it in the same box where the distribution is armed but on the other side next to the block is to say the pump is the entire distribution box and it is moved by the same crankshaft to see it you have to remove the entire distribution box.
