valve cleaning
13 years 1 month before #34954 by manual-mecanica
valve cleaning by manual-mecanica
Good I would like to know how the valves with hydrogen peroxide is cleaned without damaging the engine is 1995 and it must have a lot of carbon.
13 years 4 weeks before #34978 by manual-mecanica
Manual-Mecanica Response on the Re: Valve Cleaning
Hi Jesus289.
I am understanding that you want to find out the valves of your engine that is armed, I do not know the procedure with hydrogen peroxide, to tell the truth I did not have news of it. To do that cleaning at least you must remove the exhaust multiple to be able to firm and that the material falls abroad, normally wash with warsol or diesel. LUCK
MIGUEL
13 years 3 weeks before #35129 by manual-mecanica
I never listen to that procedure, I suppose it is to avoid disassembling the cylinder head.
In my case, the best way to decarbonize the valves is to draw the cylinder head, take out the valves and clean them. It is slow, but it is safe and keep in mind that it is the best.
Luck
