Hello, apparently is the immobilizer since the effect that occurs is similar to the one you describe. Make a scan to the system and verify if you have any fault code.
Hi Nico, look at having the alternator strap on and tense since the same Voltage Regulator of the alternator is the land signal of the pump. If the alternator does not turn the flow is cut.
