Hello, I have a problem with an Opel Corsa truck that changed the gums of the rear wheels because it had the drum wet in oil but we could not place the pedal hard, so we changed the gomites to the brake pump and how it is placed a little hard but we set the engine and it is released all the little pressure that we bleed with the engine on and nothing does not take pressure.
I hope the problem is understood, if someone has happened to him, I would appreciate it to comment, thank you now
