Cavalier 97
13 years 3 weeks before #35055 by manual-mecanica
CAVALIER 97 Published by Manual-Mecanica
Hello, for the entire ED Manuals of Mechanica, I request information from the Cavalier Model 97 Automatic The Torque of the Cabesa because it is that the packaging begins to pass the water to the carter and therefore I need to know that torque carries the head to change the packaging I outsake
13 years 3 weeks before #35057 by manual-mecanica
Manual-Mecanica Response on the Re: Cavalier 97
Hello, the torque is: first step short bolts 43 ft-lbs, long stops 46 ft-lbs, second step is added to each bolt 90 degrees, which goes well.
13 years 3 weeks before #35089 by manual-mecanica
Hello Camarada Grasias x Your information I would like you could give me more information about this machine because I do not know it if the distribution chain has tensioners and the order of teaching a lot would appreciate it greetings
