Fuel with fuel system in Voyager 95
13 years 3 weeks before #35066 by manual-mecanica
Fuel with fuel system in Voyager 95 published by Manual-Mecanica
Good I hope someone can help me I have a problem with the ignition system of a minivan voyager model 95 which when I want to light it I have to go 3 times so that it comes on and once loaded the system turns on to
the
first
13 years 3 weeks before #35095 by manual-mecanica
Manual-Mecanica response on the Re: Failure with fuel system in Voyager 95
The problem is your fuel pump
13 years 3 weeks before #35113 by manual-mecanica
Look if you have never changed your pump, then change it, once you lower your czech pump the high hose, usulously when it takes to start is because the high hose is cracked ... I would recommend that you check this of the hoses ... and if you continue like this, change your pressure regulator that is almost next to the injectors .. I hope it has been helpful.
13 years 3 weeks before #35116 by manual-mecanica
Do not be fatalistic, first check your gas filter, there are occasions that cover too soon if your gas tank is too dirty, or when it is customary to maintain the gas level in less than a room. If this is not corrected with this, the pressure regulator of the injector rail is damaged, and the worst case is that it is the gas pump.
If the truck does not stop suddenly (especially when it is already hot) you have the hope that the problem is not.
I recommend that you start reviewing from the simplest to the most advanced.
Greetings and luck.
13 years 3 weeks before #35117 by manual-mecanica
If you want to rule out that the system is downloaded charged three times before giving it starting the contact and being the third you will start if immediately starts then if the system is downloaded but, it is something else.
