Connect alarm charges in a 98 Ford Mondeo
17 years 3 weeks before #3519 by manual-mecanica
Connect alarm charges in a 98 Ford Mondeo published by Manual-Mecanica
Hello, my name is Julio. I am placing an alarm charges in a Ford Mondeo of 98, and I do not know how to connect the cables so that when the alarm is connected or disconnected, the vehicle is closed or opened. Thank you and I await an answer.
17 years 2 weeks before #3536 by manual-mecanica
Manual-Mecanica response on the Re: connect alarm charges in a 98 Ford Mondeo
You can go to the Cobra located and look for the car model and there you can find the connections scheme of the alarm system that you are installing I think you need a separate system to lower and climb the glass but you will see that with the connection scheme.-
16 years 1 month before #7903 by manual-mecanica
The only way to connect the centralized closure is to add a motor to the original cerredura, I put it in my car, since because of the type of closure that it has, it cannot be hung from the food of the engines, you must place it in the driver of the driver
