NISSAN Z24 MOD 88 ELECTRIC PROBLEM
13 years 2 weeks before - 13 years 2 weeks before #35190 by manual-mecanica
NISSAN Z24 MOD 88 ELECTRIC PROBLEM PUBLISHED BY MANUAL-MECANICA
Good day:
I have an electrical problem with a Nissan Pick Up Z24 Mod 88, it happens that the truck goes out when the current is cut and there is gasoline, the system it brings is 2 injectes and carburetor, is tbi?, In short. After the vehicle cools, lights.
This is what I have changed:
1.
-Spark plug
2
. I hope someone can help me.
Pd.: I just saw the computer and I see that the terminals have something green, such as sulfated, a little.
Latest edition: 13 years 2 weeks before for .
13 years 2 weeks before #35198 by manual-mecanica
Manual-Mecanica Response on the Re: Electric Problem Nissan Z24 Mod 88
First, the first thing, clean the green terminals you mention, and if that does not work, put a direct battery cable to a coil positibo to rule out that the contact sheet is in poor condition.
13 years 2 weeks before #35355 by manual-mecanica
Apparently we already solved the problem, we changed the pump relay and the main relay, but the real problem was, I think, I had several burned and/or bridged cables, I made an electrical diagram and chose to check the cables, slow but sure, and all good for the moment, thanks for the help.
12 years 8 months before #38146 by manual-mecanica
Manual-Mecanica Response on the Nissan Z24 Mod 88 Electrical Problem
Hello my name is Johanny and I have a very serious problem and similar to you I have a Nissan Fiera de HE Know that I can do why I am very worried about that ... I want to emphasize that I already change spark plug wires, new rotor distributor cover spark plugs and the truck is still the same that I please help ....
12 years 8 months before #38153 by manual-mecanica
Good morning, check the gasoline pump when the vehicle is extinguished, if it has no current, check the pump relay and its wiring, that was what happened to me.
