Revolution problem
13 years 3 weeks before #35206 by manual-mecanica
Revolution problem published by Manual-Mecanica
HL, let's see if someone throws me a little hand. I have problems with the revolutions of my Seat Ibiza TDI 1.9 ATD engine. Normally when I started the needle marks me 950 and then after a while I accelerates the engine a little and marks me all the time 1,000rpm and I don't know what the problem will be.
13 years 2 weeks before #35298 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with revolutions
Did you see the correct operation of the Lamda probe?
It happened to me once the Lamda or oxygen sensor probe was bad and that's why I accelerated at times.
Also check the operation of IAC (Conrollentí), these derepentes are stuck.
Luck.
