Problems with Light Light Behind Opel Astra G
13 years 3 weeks before #35228 by manual-mecanica
Problems with Light Light Opel Astra G Published by Manual-Mecanica
It is not the fuse, can it be the connection of the gear lever?, If so, what do I have to do to look and repair it? And how?. Thank you very much.
13 years 3 weeks before #35229 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Light Light Opel Astra G
How do I repair and where the connection of marching light behind the Opel Astra G ????
13 years 3 weeks before #35230 by manual-mecanica
13 years 3 weeks before #35233 by manual-mecanica
Usually if it is not the fuse, they are the bulbs. The bulb is an ON/OFF switch, where 2 input cables and another output are located, you usually find it in the exchange box. Certain where the change lever reaches.
13 years 3 weeks before #35235 by manual-mecanica
Hello, follow the following steps and you will come to a good end First make sure you have energy at both ends of the fuse looks at the color of the cables and tries to use them in the back sensor in the gearbox near the lever measures if energy arrives and with the march behind connected and the in contact measures if energy comes out by the other cable if everything is well measure And good land I hope this is lucky
