- Thanks received: 1
06-19-2025 Hits: 944 Technology
Rastaman wrote: Compa Cleled the IAC normally that motor regulates the air entry for combustion and if it is bothering you changing it because it is unlocked. Normal must sound and go out when the ignition switch you were checking that
