Mazda Tribute Sensor Cht Failed
13 years 2 weeks before #35267 by manual-mecanica
Mazda Tribute Sensor Cht Failed Published by Manual-Mecanica
I have a problem with a 2002 2.0LT Mazda Standard, they scanned it and the diagnosis was that malfunctioning of the chilindros head vulvo cht algien could desir me where the temperature vulvo is located and which means cht (Sensor cht failed), (short circuit condition or open circuit), poor electrical condition), that was the result they could not help me.
13 years 2 weeks before #35295 by manual-mecanica
Manual-Mecanica Response on the Re: Mazda Tribute Sensor Cht Failed
The temperature sensor and the CHT sensor are the same measures the temperature, it is hired in the engine butt. usually on the side.
The short circuit condition means that internally the sensor is making an internal bridge and does not change its resistance value.
The open circuit condition means that internally the sensor is cut and will not mark any type of resistance.
I hope you have helped you.
Greetings
13 years 2 weeks before #35301 by manual-mecanica
I am very appreciated by the answer I will buy the temperature sensor will replace it and comment that it turned out thanks
13 years 1 week before #35590 by manual-mecanica
Excuse my ingenia the sensor that I have located is under the escape multiple attached to Don de Unne lacaja looking from the front of the truck and only has a screw held because I try to buy it but the one they showed me is not the same as you locate
13 years 4 days before - 13 years 4 days before #35671 by manual-mecanica
That is an image sensor is an RPM sensor or firing position.
The temperature sensor is located in the cylinder head ... Try to look for it.
It's something similar to this ...
Try to look for it as a reference
Latest edition: 13 years 4 days before by .
