Good night I have a problem and I hope you can guide me. I have a GMC Blazzer 95 4x4 model with 4.3LT 6 cylinders and automatic transmission. My problem is that you notice that the 4x4 does not work that is to say on the Persione board the button that says 4 so and turns off indicating the change and the gear movement in the transmission is heard but the front wheels have no traction, checking I found that the lower part of the accumulator box finds a device as a diaphragm that has a spring but the cover cover is broken. A person tells me that the 4x4 is activated by empty and that he has a pump at the bottom of the capo but does not find any empty hose that is also disconnected by observing in the workshop manual of a user on the page I do not find that empty pump.
