Hello I have problems with the IAC valve
13 years 2 weeks before #35330 by manual-mecanica
Hello I have problems with the IAC valve published by Manual-Mecanica
Good morning: Laugh: I need to know how the IAC valve is removed and how to clean injectors manually since it does not have the necessary tool. I await your prompt response and in advance my gratitude.
13 years 2 weeks before - 13 years 2 weeks before #35332 by manual-mecanica
Manual-Mecanica Answer on the Re: Hello I have problems with the IAC valve
To do fast cleaning.
You take out the IAC plug and remove the bolts or screws according to that they hold it to the acceleration body .. be careful with the packaging of the valve. If I didn't have it, don't worry.
Then you clean it by sprinkling him cleaning, removing all existing dirt.
Then you wait for it to dry and instage it again. If you had no packaging, you must pour a slight gray silicone layer, only gray silicone (that silicone is recommended).
You put the plug again and that's it
. release dirt.
Then you take them out and the rocks again you put the filter and install them in the same order you put the plugs and to start.
Remember that is the way to clean them at home, but it is not the correct form.
Luck.
Latest edition: 13 years 2 weeks before for .
