Renault Laguna Hand brake light
13 years 2 weeks before #35361 by manual-mecanica
Renault Laguna Hand brake light published by Manual-Mecanica
Good I have a question and changed the rear brake pads of my car and the handbrake cable and I tightened it again but I stayed the light of the splash on as if I was put on the handbrake, when tensing it, the same as before it can be, alluda please.
13 years 2 weeks before #35365 by manual-mecanica
Manual-Mecanica Response on the Renault Laguna Light of Hand Brake
Check the brake contact (switch), it may be there the fault
13 years 2 weeks before #35366 by manual-mecanica
GOOD GUILLERMO FELIPE THANKS FOR ANSWER, WHERE IS THE HAND BRAKE CONTACT?
13 years 2 weeks before #35368 by manual-mecanica
Follow the handbrake plug ... They usually go on the lever
13 years 2 weeks before #35370 by manual-mecanica
Ok I'll look at it, I'll tell you thanks for your Alluda.
