I just bought a 96 Hyundai Avante and the windshield wiper does not work and read that it can be the fuse but I really have no idea what it is ... and reviewed all the fuses that go in the fuse box that goes down the steering wheel and it is not seen that it is none burned. What would be the problem
The easiest thing is to disconnect the connector that reaches the clean engine and see if it comes current when it is operated, if the problem comes it is the engine and if it does not reach it it can be co -seated to a relay under the chest not inside the vehicle.
