Hello, look I have disarmed on several occasions and yes, the guide is wider but has no implication in operation. What is relevant is that the crankshaft pulleys, especially those of diesel vehicles come with a rubber absorber, which is to avoid aciclisms in the crankshaft, that is, absorb the load of the different consumers (alternator, assistant direction, assisted direction. That the pulley has a useful life, and to know if it is in order, it is enough to make a transverse brand from the outside and go to the engine and stop it, and corroborate that the brand is not displaced. For the case of the ABS, it is simple, I detect you fail because the system detects engine in progress and turns a single wheel. The ABS controls the speed of the wheels independently to perform the necessary calculations and affect the electrovalvulas that the electrovalvulas that the electrovalvulat They handle the liquid pressures before an emergency braking situation. It is all in some cases to take a tour to take the 4 -wheel signal or do not erase the defects with any scanner for the intake of eobdii diagnosis of 16 pins.
Greetings!!
