Loss of clutch fluid Combo 1.3 CDTI
13 years 1 week before - 13 years 1 week before #35454 by manual-mecanica
Loss of clutch fluid Combo 1.3 CDTI published by Manual-Mecanica
Very good, I have an Opel Combo 1.3 CDTI of 2004. I had noticed that I lost a little liquid, but I thought I dripped a little oil, until yesterday the fool made me a little with the marches, when I disengaged, I had varied the route a bit and hooked before. Today when parking it on a slope down, when I went to start it I have realized that I had no pressure on the pedal and when the car looked there was a large stain of brake fluid under the car.
I have been looking but I have not found any manual that corresponds to my Opel model and in the User Manual does not come information about it.
If someone could facilitate or illustrate where the tank and clutch circuit is, it would be very grateful.
Gracias greetings
Latest edition: 13 years 1 week before by .
13 years 1 week before #35498 by manual-mecanica
Manual-Mecanica Response on the Re: Loss of clutch fluid Opel Combo 1.3 CDTI
The diagnosis is reluctibly easily, the liquid depocyte always goes next to the servo brake if it has an independent deposit, if it is not the case then it is shared with the brake fluid depocyte, if the stain is seen later that this is then the auxiliary cylinder that is mounted on the block looking towards the gearbox, usually if you run a little the bellows of this one looks Auxiliary cylinder then the pushing is hydraulic if this were the case the loss would be below the car just at the joint between the block and the gearbox.
