Hyundai Santa Fe Light of Traction System
13 years 1 week before #35476 by manual-mecanica
Hyundai Santa Fe Light of Traction System published by Manual-Mecanica
I have a 2007 Hyundai Santa Fe, when I go running, suddenly goes out and I turn on a wheel that indicates the 4 -wheeled traction, then I play the fuses and start walking as if nothing, path 1 km. And the same thing happens again, will it be fuse problem? What is the fuse that controls this light?
7 years 1 month before #53115 by manual-mecanica
Manual-Mecanica Response On the Hyundai Santa Fe
Hello, I have the same problem. What fuses did you move? And in the end how was it solved? Thank you
