Lord, colleagues or classmates, well waiting to have a good reception, I expose my problem, it turns out that I have a Peugeot Boxer 1.9 year 2001 that so that it can start reading a code that brings the key through an antenna, and that it goes to a module located under the direction column, well the problem is that the key has been lost and there is no way that the engine starts and I would like to Get the engine to turn since I have intervened the contact sheet but does not start because the computer does not read the Save key code that signs refuses the engine so that it does not start in order to inewly inerture these external menera and be able to leave the engine? Any comment will be grateful thanks
