Vectra B 20dth Gasail Pump
13 years 1 week before #35607 by manual-mecanica
GASOIL BUMA VECTRA B 20DTH PUBLISHED BY MANUAL-MECANICA
I have changed the diesel injection pump for a second hand and does not start, should we codify it before?
13 years 1 week before - 13 years 1 week before #35608 by manual-mecanica
Manual-Mecanica Answer on the Re: Gasoil Vectra B 20DTH pump
Hello if it is rotary with electronics, it is probably because they carry anti -theft proves that the distribution has been in its marks and the pump corresponds to the height.
If the pump is high -pressure common, those pumps should not normally code, but if you bought a second -hand, it is also broken because it is a common evil of those engines (in the Common Rail) anyway, the diesel circuit purges well (with open contact) reviews well the sleeves of the heating returns are usually cracked and drinks air again again. These cases is to catch a rebuilt bomb. If you have pre -pump submerged in the deposit some models take it.
Last edition: 13 years 1 week before . Reason: correct text and add
