JEEP Cherokee Classisc begins but does not turn on
13 years 6 hours before #35698 by manual-mecanica
Thank you, for that data I will check all the fuses of the board that is inside the vehicle, with your respective relay then I send the answer.
13 years 6 hours before #35699 by manual-mecanica
*The first step is to see if the Ecu Chekea
*second, tried with a spark plug in any capuchon to see if you have a spark
*third, do the pump go? What pressure delivery?
*Fourth, enter with a scanner
*Already my opinion, lower the manual of your vehicle, they are very complete, that can help you a lot
13 years 5 hours before #35702 by manual-mecanica
Ok I tell you that coil, they try them and where the distributor is going, he carries a sensor that is a captor also the test but you have to know how Check Engine light garment when the suiche passes if all this is buneo to know if the ECU is good a scanner if the scanner does not throw nigun sensor your problem is a cable or relex or fuse but if time when connecting it says that it does not establish link with the vehicle is bad the computer is the computer
12 years 11 months before #35750 by manual-mecanica
Thank you for your answer, check all the fuses both next to the engine and the one on the side of the co -pilot are well check the relay asd and work as well as the wiring to each of the sensors and injectors, I want to say that when trying to turn on the truck it makes an explosion (POM) by the accelerator and the exhaust sono hard that the neighbor scared and observed when observing the silencer. I want to inform that when the regulator and the gasoline pump change it turned on with failure and then turn off and not on so far I will appreciate your help.
12 years 11 months before #35845 by manual-mecanica
Brother, the solution will give it to you the same car, did you escape it ????? It is as easy as giving him three times Ignition and counting the flickers, nothing came out?
