Start R19 problem
13 years 4 days before #35658 by manual-mecanica
R19 start problem published by Manual-Mecanica
R19 Gasoline 1400 Energy Motor 94
Problem, in cold it starts well, past 3.4 0 5 minutes also starts well, but if it's 10 or 15 minutes ... nothing, I don't start, I have to wait for it to cool, this brings me head, I have told my wife that when I stop buying that I don't even stop the car .... I do not dare to think if it could be in electronic ignition ...:(
13 years 4 days before #35666 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Start R19
These kinds of problems usually pass through the starter engine you have a simple test in your house you let it walk until you make the fault, once that the fault makes the starter the starter with a wet rag or with water directly and you give it if you immediately rranca the starter engine is the problem.
13 years 3 days before #35716 by manual-mecanica
Kikemec wrote: This kind of problem usually passes through the starter engine you have a simple test in your home you let it walk until you make the failure, once that the fault makes you cool the starter engine with a wet rag or with water directly and you give it if it immediately rranca the starter engine is the problem.
Well, I forget to say that when it does not start I mean that it is not started .... the engine turns with force, new battery, motor arranke well, then my question is if eske drown, but it is a monopunto injection (too advanced for me ... k I kede in the carburetors of the 127) Know ...... What does this when he feels, lastly more often ..... thanks and greeting
13 years 3 days before #35735 by manual-mecanica
A rather important detail that you forgot hahaha but very good your Czech response that is missing to start because it may be that the fuel pump is heated and cut or the food cable of it, as it is mono point is easier to saver since it is enough that you remove the funnel and leave the throat exposed where the monkey is going you ask to some that you give you and see if you throw fuel.
12 years 11 months before #35891 by manual-mecanica
I have caught a fault .... Check and it does not come out of the coil ... of the gasoline nol If there may be any k send everything to stop it ......
