- Thanks received: 1
06-19-2025 Hits: 895 Technology
Kikemec wrote: This kind of problem usually passes through the starter engine you have a simple test in your home you let it walk until you make the failure, once that the fault makes you cool the starter engine with a wet rag or with water directly and you give it if it immediately rranca the starter engine is the problem.
