FAILURE IN PEUGEOT EXPERT
13 years 2 days before #35765 by manual-mecanica
FAILURE IN PEUGEOT EXPERT PUBLISHED BY MANUAL-MECANICA
I have a Peugeot Expert HDI 110 of the year 2005 and I stay the light of the fiery battery and sometimes turned off the battery and load well I also notice that the aerators and the air conditioning do not work when the light on and when it goes out rarely if the air conditioning works.
13 years 2 days before #35768 by manual-mecanica
Manual-Mecanica Answer on the Re: Averia in Peugeot Expert
Once a similar problem was, the cause a fuse in poor condition.
This fuse was asulfated and the loading light went out, and the calefa engine did not work.
If that is not, it may be that your alternator does not load correctly.
Luck
13 years 2 days before #35789 by manual-mecanica
It happened to me with a Ford Ranger the new alternator and yet it marked, the problem was also a Czech cut fuse that first if you do not check the alternator can have problems with the central fence where the coals are crowded, I also play this week a Peugeot 206 with that failure pledge abesses and others do not, the regulatory box is also an important factor.
