It is aselera
13 years 7 hours before #35827 by manual-mecanica
is aselera published by Manual-Mecanica
: EVIL: Greetings Problem with my car Ford Taurus 96 after thirty kilometers was aselera for 15 seconds later normal le doi gas and repeats the same thing the pedal of the gas and another 15 seconds ase that and thus consecutively consecutively because in Peso? thanks beforehand
12 years 11 months before #35842 by manual-mecanica
Manual-Mecanica Response on the Reelera
Good compa, I would say that you begin by the accelerator cable for those that are not oxidized inside and for checking empty leaks, that is, hoses disconnected from and to the multiple admission, I recommend you to find empty leak use clean carburetors in spray, you are gradually applying it on the different points of the multiple also apply it in the O-Rings of the injectors because sometimes they break for being very dry, I hope it serves you, greetings-
12 years 11 months before #35975 by manual-mecanica
Greetings Electro from suede thank you very much I did not have much chansa to check the hoax Haorita Boy to check my car where I disagree later I tell you.
