Mitsubishi Montero Sport 4x4 Vivracion in the Trans
12 years 11 months before - 12 years 11 months before #35941 by manual-mecanica
Hello friends, I have a mitsubishi 2000 Montero Sport, I bought it because it was necessary Motor or in the transmission because everything does not feel as if the TranMision is tie
Latest edition: 12 years 11 months before by .
12 years 11 months before #35955 by manual-mecanica
Good compa, starting the impression that the problem you have or at the bar crossings also called crossbolts or in the same traction bar. That effect of when you release the accelerator gives me the impression that is when it stops pushing the box to the rear axle and the same axle compensates the turn, I do not know if I explain well. Review the crosses that are surely damaged.
12 years 11 months before - 12 years 11 months before #35958 by manual-mecanica
Thank you for your kind attention already has new echo crossings before; to buy it already had that problem because the sensor was new and in cash inside the montero and I know the vivraction of which you talk to me and to check and all this Vien has no game is as if it was shook motor and transmission together look in this link Transmission Vibrates to Heavy Shaking Between 30-45 mph 30-45 mph [URL = http: // transmission vibrates to heavy shaking Between 30-45 mph transmission vibrates to heavy shaking Between 30-45 mph-
fixya www.fixya.com/cars/t1516307-transmission...ations_heavy_shaking Speed ​​range is the same and when you go on road 0 vivries 45 miles onwards the bar is not crooked or loss how you want to thank you for your help :)
