- Thanks received: 1
06-19-2025 Hits: 895 Technology
The IAC valve is an actuator not a sensor, and my in idle regulates well, it is only when Ecello suddenly ..Extrella wrote: Hello, I recommend reviewing the IAC censor, its seal, and cavities of the base of this censor, also check the connection and its cables since they are split or cut internally and is working with the computer's memory signal.
