Problems on ford countour 96
12 years 11 months before #36096 by manual-mecanica
Problems on Ford Countour 96 Published by Manual-Mecanica
Good tdes, I have a contaur 96 and the problem is K does not turn on and few occasions if it does but with failures, change the computer but follow the same problem .. I will thank your answers
12 years 11 months before #36101 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems on Ford Countour 96
If your car is 6 cyl the very common problem is the general harness
12 years 11 months before #36106 by manual-mecanica
The first thing is to see because it does not start if it is lack of spark or fuel, since depending on that is the prosecutor and cheko to follow.
12 years 11 months before #36156 by manual-mecanica
Exact .. you didn't tell us if the starting engine revolves .. and if apart from the computer it has been checked or some other job
greetings
12 years 11 months before #36430 by manual-mecanica
It has a spark, it has fuel, and the engine has good compression, and it is 4 cylinders, starts but without force with the accelerator thoroughly, it seems that the air is returned by the carburetor .... Thank you
