Auto goes out and does not turn on.
12 years 11 months before #36192 by manual-mecanica
Auto goes out and does not turn on. Posted by manual-mecanica
Greetings, I have a small consultation; It happens that my neighbor has a Honda Accord ex 1996 and when he turns on the car on without any problem but after he is driving him about 15 to 20 minutes the car goes out and does not want to set him anymore, he has to wait for half an hour in what he cools and then be able to turn it on to last another 15 minutes on and be able to take him home.
The mechanics of the neighborhood told him that it was the coil and a few more things and he changed them but the car continues with the problem I have only told him that it must be some resistance or capacitor on the computer that when he warms he neighbor ... thanks before hand ..
12 years 11 months before #36196 by manual-mecanica
Manual-Mecanica response on the Re: Auto goes out and does not turn on.
Estimated rramosf4.
Practically, what happens to your friend is that the engine is covered and the causes range from the simplest such as the electrical system (the spark plugs) and the water and fuel filter clogged to problems with the idle regime, Fujas in the admission collector.
I recommend that you ask your neighbor, first of all, how is the battery, spark plugs and the water and fuel filter. How much does it change them? second if nothing works that perform a test to the PCM (propulsion system control panel) to know the coding of problems that generate the resistance you are talking about.
12 years 11 months before #36434 by manual-mecanica
The failure is likely to be the ignition module, it is a very typical symptom of this piece
12 years 11 months before #36435 by manual-mecanica
Czech the rider and camshaft position sensor, the scanner that marks?
12 years 11 months before #36436 by manual-mecanica
The problem and the main relay ... here is a very useful post ... luck. Foros.hondaclub.com.ar/showthread.php?t=52488
B)
