Fiat Uno 1.3 8v fault
12 years 11 months before #36342 by manual-mecanica
Fiat Uno 1.3 8V Failure Published by Manual-Mecanica
Hello, I would like to consult, in a one -one Fire engine, it regulates quite well, but it does not accelerate, it gives the sensation that the covered escape was, but this is the one that has the tacho at the multiple output (mod new), Spero answers, thank you.
12 years 11 months before #36343 by manual-mecanica
Manual-Mecanica Answer on the Re: Fiat Uno 1.3 8V Failure
To know if it is the covered escape removes the downspout and try if you do not improve you have the time or the piñon wedge of the Sigual this bad has to check all that and thus discard
12 years 11 months before #36358 by manual-mecanica
Hi Mamigo, apart from what the partner tells you, check the gasoline filter that is not covered, tell us how you go, greetings. : Laugh:
