Hello everyone: today my car (Megane Classic 1.4 16v phase II) circulating by road I have noticed that I lost strength, (as if lifting the foot of the pedal) I give a couple of stomps to the accelerator and recover again, but only momntaneously. What is it due? Is it serious? Do you need any more data? Graaaaaaaaaacias and a hug
Hi: You are likely to have a problem in your megane butterfly box. This has an electronic potentiometer that when spent can cause the failure that is presented to you. Placing the computer, you can know if the fault is there; Even with a tester you can try its operation.
