Ignition failures with mitsubishi sign
12 years 11 months before #36418 by manual-mecanica
Ignition failures with Mitsubishi Sign published by Manual-Mecanica
Good night! I have a sign 1.3 Q presents 2 failures. First: Do not turn on in the morning in the first attempt as it should be, after several times lights with failures and I have to keep it accelerated until it is normal, the rest of the day it turns on normal. Second: When I turn on the air conditioning of the car, it seeks to extinguish causing the compressor, to pledge and turn off because the car does not grab minimal. It should be noted that I have changed: rotor, distributor lid, spark plug cables, spark plugs, I lowered the camera, bought new valves (I mounted and nodded). Still still with the failure. Thanks for the advice that can offer me.
