Friends I have this problem with this car a Kia spectra, engine 4 cyl, 2.0, firstly the chain of time, the chain (complete kit) and the respective damaged valves, after all this the car the car lights without any problem, the engine is heard serenite without noise, but the problem that when accelerating the engine does not give anything of power does not give, later it does not give this. And to turn it on it, it is necessary to disconnect the opposition sensor from the EVAS tree, we change this sensor and the problem persists, an interesting detail is that if we let that sensor disconnected the car turns on and does not go out, it can walk but without the normal power.
The diagnosis that the scanner sends when connecting to the car indicates an error of relationship between the crankshaft and the EVAS tree, we already review the engine time and apparently this correct would like to know if this procedure takes some special step ...
thank your comments
