I have a fault in my Ford Explorer '99 truck
12 years 11 months before #36473 by manual-mecanica
I have a failure in my Ford Explorer '99 van published by Manual-Mecanica
Well the problem is that when I pass through spoiled pavement or some inclined streets the derrepent truck accelerates alone and returns to normal, what can that be?
12 years 10 months before #36499 by manual-mecanica
Check motor and change supports, wiring to see if it is a loose mass cable or a connector or the loose acceleration body or damaged support
12 years 10 months before #36506 by manual-mecanica
It may be that your motor supports no longer serve:
for that reason when passing through the road the vibrate truck along with the engine in that way the detonation sensor interprets it as if the engine were vibrating dema and the computer accelerates it to stabilize it
