LANOS
12 years 10 months before #36588 by manual-mecanica
Lanos published by Manual-Mecanica
My Daewoo Lanos of the year 2001 has the following problem when I grab temperature I stop and then I do not have to wait 10 to 15 min so that I will give up the electro fan works the equal temperature clock I do not
12 years 10 months before #36812 by manual-mecanica
Manual-Mecanica Answer Lanos Theme
Good I have the same a Daewoo Lanos 2001 The fault you describe is strange when you say that you stop it, you turn it off or turn off, because if it is probably turned off you are the gasoline pump for geeneral there are some pump marks that are damaged in that way when heat stop that goes from the battery to the block
12 years 10 months before #36815 by manual-mecanica
good
what do you mean that you don't part ???
What is caught but does not move the car?
If that is your problem and your car is automatic, the most caused thing is that your transmission is being heated
too
12 years 10 months before #37022 by manual-mecanica
B) Good friend I have some sugencies for your problem:
1 It can be the fuel pump that functional product with a low level of fuel is overheat and stop functional a frequent problem in pumps submerged in the pond since they use the fuel as refrigerant.
;) 2 It can be the temperature censor etc.
Well, what happens is that when being damaged you can inform the ECM, ECU
: Whistle: switch FAVING PHASE When he is hot, he does not respond and when he fucks it,
: Whistle: he does this one only happens to you when you stop it or have a scoring temperature and walking stops alone?
Well I hope these advice will help you and luck with the subject
12 years 10 months before #37076 by manual-mecanica
Fix the spark plugs if you are red socks is a thermostat problem
