I also appear if they smell like gasoline, it may be wet and if so it is a product of a high fuel and once wet I recommend that you change them
also verify the state of the spark plug cables.
Well, those of us who have to check the little and Ruin CKP sensor that is the crankshaft position sensor,
this sensor if the vehicle fails stops and does not start because it sends the tight for the combistible pump, the position of the piston, the rpm of the engine, for the ignition.
You can be loose, dirty your contacts or wiring to be peeled,
they are Hall effect therefore they carry an internal coil and resistance can be measured with a simple multitester.
Finally, check and clean with clean contact the terminals of the plugs of the other sensors and check the cables.
