Hydrauilic assisted direction problem
12 years 10 months before - 12 years 10 months before #36593 by manual-mecanica
Hydrauilic assisted address problem published by Manual-Mecanica
The direction of my Chevrolet truck is super hard to turn to the sides they tell me that it is the hydraulic aciete pump but I do not know why apparently if the oil circulates.
We have done everything that a manual tells us to disagree at the exit to the pump, the pipe that enters the steering box and after which it leaves, the oil leaves but I do not have how to try the pressure and I continue with the problem that when I am going slowly or for parking it is super hard, it becomes completely mechanical and it is with hydraulic pump.
Latest edition: 12 years 10 months before by .
12 years 10 months before #36729 by manual-mecanica
Manual-Mecanica response on the problem in the hydrauilic assisted direction
The pump may be oil but not enough to open the valve
12 years 10 months before #36747 by manual-mecanica
This is also but you must also check the state of the oil and the pressure of the same, as well as the tension of the belt.
12 years 10 months before #36783 by manual-mecanica
hello.
Your hydraulic or servoasistidal addresses?
