CAVALIER ELECTROVENTILLADOR
12 years 10 months before #36615 by manual-mecanica
Cavalier Electroventilator published by Manual-Mecanica
Hello everyone, someone could tell me how to operate the electro fan I do not know what the sensor is or where it is located since a little hand was not on for thanks is a Cavalier 2.4 year 96
12 years 10 months before #36618 by manual-mecanica
Manual-Mecanica Answer on the Re: Cavalier Electrotiler
Hello, how do
you look at the temperature sensor you can find in the main hose that goes from the tradiator to the engine and passes under the air inlet tube to the engine is detyras of the water clumping where it connects that hose such see you find 2 almost identical sensor but one is a sensor and the other is a bulb that controls the temperature needle on the board to identify what you are only Fan automatically turn on that is the sensor to this function, it is called "saving the house" you also have to take into account the food relief relay is located in the relay and fuses box that is on the side of the car's battery you can look at its location in the back of the box of the box
Note: If the first test does not work it does not work the fan relay with the air. vehicle and wait for it to heat at the normal temperature if the fan ignites there is the uvication of the problem only replaces the relay for a new one
12 years 10 months before - 12 years 10 months before #36622 by manual-mecanica
Good friend, for 10 years and now there to some clients with Cavalier and Century and others, and placed an adaptation with a bronze tube and a universal vulvo like that of Monza or Fiat of Temp 68 to 78 approximate in the right hose and a pin goes to earth and the other to Relex de la Fusilera or with a separate fuse. since customers did not like the PCM to activate approximately 105. The vulvo
Latest edition: 12 years 10 months before by .
12 years 8 months before #38118 by manual-mecanica
Solved the electrventilator problem chooses to put a vulvo of universal temperature of 86º to the metallic tube of water and the needle of the tº board works perfectly.
