Hi Garis, disassembling the upper lid of the injected pump requires knowledge of mechanics and having the necessary tools for assembly, I do not recommend that you do it. Regarding the noise after the dashboard, it is the air recycling spring, for the engine part you have to remove the right cover of the hollow hole clean-coer-mooring engine. There the connector of the trapillade, rectangular connector is lodged and I think I remember 3 cables, disconnect it and the noise is over. I hope the contribution serves you, Salu2 ...
