How to measure the box from the box
12 years 10 months before #36636 by manual-mecanica
How to measure the box from the box posted by manual-mecanica
I have problems with a noise from the automatic box when starting and by decelerating is a 2008 Caliber, how can I do to measure the oil from the box since it does not have a rod to measure it?
12 years 9 months before #37805 by manual-mecanica
Manual-Mecanica response on the subject how to measure the box from the box
You must have an Allen key plug down the side, if you are the Aeite level, it will drip a little if you do not, it is because it is missing.
Luck
12 years 8 months before #37829 by manual-mecanica
This has a level plug, take it out and see if it drains if it does it is fine at level, you must check the state of the oil and the filter too.
