Stop Peugeot 306 light
12 years 10 months before #36648 by manual-mecanica
Luz Stop Peugeot 306 published by Manual-Mecanica
: Ohmy: Hello, I have in Peugeot 306 xrbreak 1.6 year 2001 to which the stop light was lit. When reviewing the manual, it says "centralized warning witness" imperative to stop. What can this be due? Is it serious for the vehicle?
12 years 10 months before #36659 by manual-mecanica
Manual-Mecanica Answer on the Re: Luz Stop Peugeot 306
Hi Magago2009, which is turned on the stop light is not good, neither for your car nor for any. First you should see if the stop light is turned on accompanied by some other, oil pressure, motor temperature, etc. You should go as soon as possible to a workshop that verifies the car, because the failure may be of some motor, lack or water sensor in the radiator or something more serious that can cause a much greater breakdown. You will tell us.
